02-17-2003 05:13 AM - edited 07-04-2021 08:30 AM
Some questions about the trunk between switchport and an AP350:
how to configure the trunk between Cat6500 an AP350 (is set trunk 4/19 on
dot1q in conjunction with clear trunk and enable trunk at the AP enough)?
which VlanID is the fec0 Interface associated to (the native Vlan)???
Vlan ID must be in the range of 1-16 or can i use for example VlanID 10, 30, 241 (and of course less then 16)???
are there advanced troubleshooting cmdline tools available for AP350?
sometimes i've get a number of errors at the AP when i've changed the native VLAN:
0xd8bb70 (tRcv_fec0):
*** devEthernetEND_c::RecvFrameList: Corrupt 802.3 header (payloadLen 46,
encoded as 64) -- processing anyway!
02-18-2003 09:12 AM
Please go through above url , AP only supports 802.1q trunking .
Above url shows how to enable trunking on AP .
make sure you have same native vlan on AP and on switch
02-19-2003 04:51 AM
Hi Nilesh,
i think there are some answers to my questions.
thank you
