Skipping Web Passthrough for a single client
ALIAOF_
Level 11
Level 11
Is it possible to set one client up so that it can go online and does not have to open up a web page and click on the "Accept" button?
Trying to get this working for Apple TV which does not have a browser.  So since until a client clicks on the "Accept" button no traffic is passed clients can't see the Apple TV and connect to it.  However I don't want to disable the web passthrough option for every one.
19 Replies 19
Scott Fella
Why not create a new SSID for the Apple TV and use AP Groups to specify what APs will broadcast that SSID. Well you will not broadcast it to the clients but the AP will have it:). Then map that SSID for Apple TV to the same subnet as the iPad users, etc. You can't exclude devices from webauth.
Scott Fella
Sent from my iPhone
-Scott
Unfortunately that is not possible due to our setup.  I do have a different SSID for the Apple TV and both SSID's are mapped to the same network.  However the issue is that the first SSID have "p2p blocking enabled" and second one doesn't.  So all the clients are connecting to that too.
What I tried was the following:
Setup MAC Filtering, then setup "MAC Failure Action" to go to the web pass through redirect page and added Apple TV's MAC to the allowed MAC list however.  That sort of works but the clients after they hit accept it just keeps bringing that page up and does not finish the authentication.
I don't know why SSID is doing what. What I'm saying is that you create a new SSID just for the Apple TV (I think it supports WPA2-AES psk) and then that would map to the same vlan as the iPad users. So the Apple TV and iPads would be on a seperate WLAN SSID.
Scott Fella
Sent from my iPhone
-Scott
Already done that but then the iPad users if they do not connec to the same SSID they won't be able to see the Apple TV because that particular SSID have "P2P Block Action" set to "Drop".
Do you require that... If P2P is enabled and even if the Apple TV and iPads are on the same subnet, you are preventing the devices from communicating.
Scott Fella
Sent from my iPhone
-Scott
It is not enabled on the second SSID where Apple TV and the iPad users are connected
SSID1 -------------> 192.168.1.0/24 --------------> Regular guest users (p2p actions drop)
SSID2 -------------> 192.168.1.0/24 --------------> Apple TV and users who are connecting to Apple TV only (p2p blocking disabled)
This is what I'm trying to describe:
SSID2 -------------> 192.168.1.0/24 --------------> Apple TV users who are connecting to Apple TV only (p2p blocking disabled)  WebAuth
SSID3 -------------> 192.168.1.0/24 --------------> Apple TV only (p2p blocking disabled) WPA2-AES psk
-Scott
Just tried that scenario too but iPad won't see the Apple TV still.
I'm just surprised that there is no option to exclude a client if we want and if there isn't how come that other scenario with the MAC filtering isn't working.  May be I should create a case with Cisco.
Okay... do you have the following configured:
Multicast mode set to multicast
Global multicast enabled
IGMP Snooping enabled
Broadcast forwarding enabled
-Scott
You also might have to do this on the switch.... depends if you still can't get the ipads to see the Apple TV:
https://supportforums.cisco.com/message/3519224#3519224
-Scott
No I'm going to configure that and test it next week and post back the results thank you for your help and if that does not work I'll try wiring it too and see if that helps.
No problem... I assumed that you had the multicast stuff already enabled.  Give it a try... there are other post regarding the Apple TV that you might want to look at, but it works with some configuration changes.
-Scott
Good morning Scott, just a quick question.  I have enabled all those.  But I do get a message that the multicast IP is reserved by IANA it might not work properly.  I have the IP set as 224.0.0.1.  Should I just ignore that message?
that address shouldn't be configured anywhere.  It is the address that a device will send packets too.  When you configure multicast in your network, you should use a 239.x.x.x address, as this is reserved for locally scoped multicast groups.  Think of it like an RFC 1918 address for the clients.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
