Skipping Web Passthrough for a single client
ALIAOF_
Level 6
Level 6
Is it possible to set one client up so that it can go online and does not have to open up a web page and click on the "Accept" button?
Trying to get this working for Apple TV which does not have a browser.  So since until a client clicks on the "Accept" button no traffic is passed clients can't see the Apple TV and connect to it.  However I don't want to disable the web passthrough option for every one.
19 Replies 19
Update, tried this with all the multicast settings configured on the WLC but still doesn't work if clients are on a different SSID.
Okay... So if they are on the same SSID it works?
-Scott
Well I just tested my Apple TV and I put my iPhone and iPad on a different SSID but on the same subnet as the Apple TV and it worked for me.
-Scott
Yes but one of the SSID where clients are has p2p blocking enabled so when I try to connect to the Apple TV from the clients that are on the SSID where the p2p blocking is enabled they can't see the ATV.
Well that feature "P2P Blocking" is doing what it does. Not allowing communication with other wireless devices. You will need to remove that if you want the devices to communicate with the other devices... Apple TV.
Scott Fella
Sent from my iPhone
-Scott
