Slow web GUI at WLC 5520
Mohamed.Ashraf
I have 2 WLCs 5520 HA , When moving from tab to another tab it take long time. I tried to use different browser like Chrome, internet explorer and FireFox but i found same issue.
IOS software: 8.3.143
Thank you
   Try to disable HTTPS Redirection and WebAuth SecureWeb 1. This require WLC to be rebooted.
-If I helped you somehow, please, rate it as useful.-
Flavio is correct - this is documented in https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf74866 fixed in 8.7.102.0 and later code.
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/118826-config-https-webauth-00.html warns "note that there might be a slight reduction in the throughput when redirection over HTTPS is used."
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/115951-web-auth-wlc-guide-00.html#anc6 says "Be aware that this is resource consuming for the WLC in case many HTTPS requests are sent. It is advised not to use this feature before WLC version 8.7 where the scalability of this feature was enhanced." Below that there is a table of expected redirect scaling.
From our experience this can cause incomplete loading of WLC GUI web pages, and gets even worse if there is any packet loss or increased round trip time between browser and WLC.
