Slow when connect cisco Aironet 2700, series AIR-CAP2702I-F-K9
asaputro
i have a problem when connect cisco Aironet 2700 series AIR-CAP2702I-F-K9, my taskbar menu on windows 10, always loading, when i connect to another wifi no use cisco aeronet, the loading on the taskbar not happened.
Thank you for your response and sharing on similar matters.
Thx,
Ary
marce1000
  - Make sure  that the AP is using the latest firmware available and also that the Wifi drivers are up to date on the PC ,
 M.
marce1000
 M.
asaputro
Thank you for your response and solution @marce , I will check that first.
Check the SSID configuration and make sure client can reach DHCP server.
Assuming you are using Mobility Express, verify your WLAN/SSID configuration.
Use "show wlan summary" & "show wlan <wlan number>commands to verify.
Also, you can connect a laptop to the switch port in the same VLAN as the WLAN/SSID and see if your laptop gets an IP address.
Make the WLAN open (without any security) and see if it connects.
Jagan Chowdam
/**Pls rate useful responses**/
Thank you for your response and solution @jagan.chowdam.
