Small Cell 5310
Nana Banahene
Level 2
Level 2
1. Has any one deployed the 5310 modules? 2.Besides the module what else does one need to get. to make cellular and wifi work. My understanding is that for cdma and gsm protocols to work with the modules, one needs switches and routers that have those protocols in their IOS, is that correct? 3. What antennas will one need for layer one to pick up the frequencies for cellular, whether it is 850, 1900 or 2100 as well as the standard 2.4 & 5ghz?
I have seen this document and its not what I'm looking for. Sorry if I wasnt clear. Thanks anyway.
