Smart Licensing
Kevynjr37
Frequent Visitor
Frequent Visitor
Hi Everyone,
I really appreciate some assistance in licensing a vWLC9800-Cloud. It is my first time working with smart licensing using policy. I have 120 APs, 50 of the APs have joined the controller, and the other 70 could not. I then went through a Cisco document that said a certain number of APs would join the controller, but you have to register for the rest of the other APs to join the controller.
I can't get my head around the smart licensing thing - I went through the Cisco docs and watched videos, but it is still not helping.
I would appreciate it if anybody shared the commands I need in WLC to register the license.
I've already created the virtual account and generated the token, which I find simple.
Best Regards,
Kevin
15 Replies 15
@Scott Fella remember that smart license enforcement was introduced on 9800-CL.  It will allow up to 50 APs to join without license activation.  Any more than that only allowed after activating the license so Kevin is right.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-7/release-notes/rn-17-7-9800.html#Cisco_Concept.dita_36dcc319-36c4-4368-b1db-da5660b72211
Note
Starting from Cisco IOS XE Cupertino 17.7.1, the Cisco Catalyst 9800-CL Wireless Controller will not accept more than 50 APs if the smart licensing is not connected and up.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
