Sniffer for CISCO 350 PCMCIA card
david.kamarad
Heloo,
I need some sniffer for this card. I can't test that traffic is encrypted. I need show the encryption to customer that is realy working good.
Do you know anyone about some sniffer fo WIN??
Thank you
bbenton
We use WildPackets Airopeek NX. www.wildpackets.com.
Network Stumbler also works with it in the later versions, but it's not really a sniffer.
I downloaded and try wildpackets but when i use the drivers for card which i must download from wildpackets web, the blue screen is on my windows2k. I tried it on XP and the blue screen was there too.:-(
With default driver from cisco, the wildpackets sniffer can't work..
David
Don't know what to tell you, it's working great for us on both 2k and xp. You might want to get in touch with wildpackets support. We had no trouble with either of the above at anytime. We've had it about 6 months. We've been successful on a Dell Latitude, and 600e, T23 and T30 IBM's. Normal LEAP and wireless connectivity work after the wildpackets drivers are installed too so we're way happy replacing the way overpriced NA sniffer and support.
It seems both vendors require use of their Aironet drivers, whch means you cannot use upgraded Cisco wireless client drivers to be an up-to-date wireless user and a wireless packet analyzer on the same machine.
