SNMP monitoring data flow per SSID returning disabled
benlilagan
Hi all,
I'm trying to poll the WLCs at our sites via SNMP to get data rates.I found what I believe are the right OIDs in the CISCO-LWAPP-WLAN-MIB but all of my controllers are returning a value of 0 which, per the MIB, means that setting is disabled.
These are the OIDs I am using:
cLWlanSsidDSAverageDataRate OBJECT-TYPE
    SYNTAX          Unsigned32
    MAX-ACCESS      read-write
    STATUS          current
    DESCRIPTION
        "This object specifies Average
        Data Rate per user on downstream.
        Value of 0 indicates the feature is disabled."
    ::= { cLWlanConfigQosEntry 9 }
cLWlanSsidUSAverageDataRate OBJECT-TYPE
    SYNTAX          Unsigned32
    STATUS          current
    DESCRIPTION
        Data Rate per user on upstream.
    ::= { cLWlanConfigQosEntry 10 }
cLWlanSsidDSBurstDataRate OBJECT-TYPE
    SYNTAX          Unsigned32
    STATUS          current
    DESCRIPTION
        "This object specifies Burst
    ::= { cLWlanConfigQosEntry 11 }
cLWlanSsidUSBurstDataRate OBJECT-TYPE
    SYNTAX          Unsigned32
    STATUS          current
    DESCRIPTION
    ::= { cLWlanConfigQosEntry 12 }
cLWlanSsidDSAvgRealTimeDataRate OBJECT-TYPE
    SYNTAX          Unsigned32
    STATUS          current
    DESCRIPTION
        "This object specifies average real time
    ::= { cLWlanConfigQosEntry 13 }
cLWlanSsidUSAvgRealTimeDataRate OBJECT-TYPE
    SYNTAX          Unsigned32
    STATUS          current
    DESCRIPTION
    ::= { cLWlanConfigQosEntry 14 }
cLWlanSsidDSBurstRealTimeDataRate OBJECT-TYPE
    SYNTAX          Unsigned32
    STATUS          current
    DESCRIPTION
        "This object specifies burst real time
    ::= { cLWlanConfigQosEntry 15 }
cLWlanSsidUSBurstRealTimeDataRate OBJECT-TYPE
    SYNTAX          Unsigned32
    STATUS          current
    DESCRIPTION
    ::= { cLWlanConfigQosEntry 16 }
I am able to successfully poll other oids on these controllers and I receive expected values. I can't seem to find any documentation about how to enable this monitoring. Any help would be appreciated
kenny.wallrath1
I think you are looking in the wrong MIB. Try to check out the Airespace MIB "AIRESPACE-WIRELESS-MIB"
There you also have a section with your QoS Rates.
kenny.wallrath1
