AP relacement for Cisco Aironet 1130 Series
Rickey369
Hi All,
My office is using the Old Cisco Aironet 1130 Series and planing to replace .  what is the best replacement that i can have for this.
The Site has around 90 Users sharing 8 AP and  WLC is deployed in the Site ( WLC 4400 series-- do i need to replace this WLC as well if im going with the new AP )
Thanks. Pls help.
Leo Laohoo
You need to be looking at the Cisco 2800.
patoberli
I also suggest the 2800 and have a look at the new feature Mobility Express (no more need for a standalone WLC with 8 APs).
Sandeep Choudhary
you can check 2800 series AP but then you also need to change the WLC..as 2800 AP first support SW is 8.2.110.0
Dont forget to arte helpful posts
