SNMP on APs
sprocket10
Level 5
Level 5
Is it possible to enable snmp on APs?
Stephen Rodriguez
Are these AP joined to a WLC? If they are, hen no. If they are not, then yes
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Sandeep Choudhary
HI,
configure the Simple Network Management Protocol (SNMP) on access point.
http://www.cisco.com/en/US/docs/wireless/access_point/12.2_15_JA/configuration/guide/s15snmp.html
Hope it helps.
Dont forget to rate helpful posts.
kaaftab
Level 9
Level 9
yes you can enable SNMP
Stephen Rodriguez
Steve
HTH,
Steve
