SNR and RSSI Values.
k_sinjish
HI ,
What is the  tha average ,minimum and maximum  values of  SNR(Signal to noice ratio ) and RSSI (Received Signal Strength Indicator ) in  cisco  access points   .
And how it is depends on the client connectivity with the Access point.
Thanks & Regards,
Sinjish.K
35 Replies 35
Best explanation I have ever seen regarding this topic! Thanks!
This is RF theory in a nutshell. Very well articulated Kayle
Pls correct about SNR as below:
S+ -N  is a wrong math equation. S-(-N) is corect equation _ -55- -95 = -55+95=40db
If your signal and noise measurements are already in dB form, simply subtract the noise figure from the main signal: S - N. Because when you subtract logarithms, it is the same as dividing normal numbers. The difference of the numbers is the SNR.
k_sinjish
Hi Kayle ,
It is highly explanatory and really helpful.
Thanks a lot
Thanks & Regards,
Sinjish.K
Abhishek Abhishek
The received signal strength indicator (RSSI) represents the value in dBm of the signal strength at which a wireless packet is received. Figure 4 shows the scatter plot of approximately 200 RSSI values received at the WSM and primary radio collected from different points. The primary radio is the internal radio of Cisco Aironet 3600i.
Figure 4.      RSSI Comparison between WSM and Primary Radio
Figure 4 shows the high degree of correlation between the RSSI for the two radios. On average, the RSSIs received by the primary radio are about 2 dB stronger than the corresponding RSSIs from the WSM. This clearly indicates that the WSM has similar coverage to that of the Cisco 3600i access point.
gohussai
Level 4
Level 4
Check the table below.
http://www.cisco.com/image/gif/paws/68666/wireless-site-survey-faq-1.gif
