Showing results forĀ
Search instead forĀ
Did you mean:Ā
solution for 500 users
eng_adel273
Level 4
Level 4
We have  500 users , need to use the wifi ,what is the best device support these users & solution
10 Replies 10
Leo Laohoo
If you want the WiFi to work from day 1, then get a WiFi site survey done properly by a professional.
JPavonM
@eng_adel273 no one device in the market should be able to support such amount of devices conneccted to the same radio interface, this is only marketing.
It all depend on capacity so when all users are connected to the Wi-Fi performace will drop dramatically, unless you have a good design done by professionals. As @Leo Laohoo advised, performing a Wi-Fi site survey will provide load balance through the use of multiple APs on different channels staggered along the area, plus redundancy.
Considering this 500 users will on the same place, considering you already did the RF planning with, at least, a predictive Site Survey,
then you can start think of Divices.
 You can use two Cisco Catalyst 9800-40 and about 35 Cisco Catalyst 9100.  If you are building this in one floor, I recommed you to use external antennas.
 For Biuld with multi floor, then the scanrio can change.
Dear Sir
We need only device or 2 device maxium to connect 500 user by wireless.
the user are in one area "Camp"
Well, this is impossible.   Phycially impossible.
Cisco has new AP models with tri-radio option (9130AX and 9136AX) which can reduce the number of APs in high density areas. But for 500 users you'll definetely need more than 2 APs and also a controller (9800 series controller or the Mobility express option) depending on the usage.
You also have the Cloud based Meraki option which doesn't need any physical controller but the renewable subscription.
Again, this depends on your usage requirement and the area size which need to be covered. In your case, you should consult a professional and get a survey done as many people recommended. Otherwize no point if placing just few APs with high Tx power configured.
Thank you for your advise
Please can tell me the maximum user supported  for one device 9136AX
The maximum device account for ANY access point depend on the load, I mean, if the devices are heavely forwarding traffic, or using near real-time applications (Teams, Zoom, voice) then the capacity decreases if you want to keep a god quality of experience. Take into consideration that is not only the load in your AP and channel, but the load of all neighbour APs on the same channel.
As previously said in this thread by all professional people, 1 or 2 APs in your case is not going to be enough, and you need to conduct a WLAN survey.
OR you can roll the dice and pick whatever number and model of APs and place them in whatever location, and see what happen, at the end, it's wireless and all people can see the SSID and connect so where is the problem? šŸ˜‰
You come here to ask experts for their advice and then choose to ignore it?
If you want a decent service then have it done by an experienced professional who understands wireless network design, otherwise don't do it at all because the service will be DREADFUL if it even works at all.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Leo Laohoo
@JPavonM, @Rich R, @Flavio Miranda,
I am no longer participating in this thread.  If the op wants to go down this path then it will be done so without my recommendation nor assistance.
Unsubscribing.
