Solution for wireless guest access password
Does any of you know if there is a cisco solucion that handle guest users in wireless network where the guest user access a portal
and can get a temporary password or can receive by email the password?
regards
mmangat
Level 5
Level 5
A sponsor user is a person who creates the guest user account and is  often an employee of the organization; for example, a lobby ambassador  who creates and manages guest user accounts through a sponsor-oriented  web portal. The Cisco ISE authenticates sponsors through a local  database or external Lightweight Directory Access Protocol (LDAP) or  Microsoft Active Directory identity stores.
A sponsor portal allows a sponsor to create temporary accounts for  guests, visitors, contractors, consultants, or customers to perform HTTP  or HTTPS login to gain access to the network. The network could be a  corporate network or access could provide access to the Internet.
You can provide account details to the guest by printout, email, or SMS.
The following cisco doc provides complete details:
http://www.cisco.com/en/US/docs/security/ise/1.0/sponsor_guide/ise10_sponsor.html
Hi Mantej,
Thanks a lot for your info an the link, great reference.
Base on this is requiered WLC + LAPs + ISE , and optional LDAP
regards
