Solution Requested...
premaximus
Community Member
Dear Experts...
I need to propose a solution based on the following...
Need 3.5 GSM Card to connect the Internet, and want to Use Wireeless WIFI Module to connect local (LAN) users.. with some restrictions to allow to conenct only mentioned Internet sites using Cisco Router...
Is there any Cisco router which can have 3G GSM module + Wireless Module.. in it.. so which Cisco device I can use to impliment such scenrio...
Thanking you in anticipation,
Shahid
dennischolmes
Level 11
Level 11
You could use a mobile access router if need be. 3200 MAR.
