Solved: Same SSID with EWC and WLC?
Tenere
Good morning,
in our company building we use an vWLC (8.3.150.0) with several 3602i and 1142 APs (hence the old software).
We plan to upgrade our network to C9115 with EWC.
Question:
Is it possible to use EWC and vWLC in parallel with the same SSIDs (like Mobility Groups between WLCs) in order to migrate "soft"?
Best regards,
Joerg
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_c9800_wireless_controller-aireos_ircm_dg.html
  • The IRCM feature is not supported on the following Cisco AireOS Wireless Controllers:
    • Cisco 2504 Wireless Controllers
    • Cisco Flex7510 Wireless Controllers
    • Cisco WiSM 2 Controllers
    • Cisco Virtual Wireless Controllers (vWLCs)
Mark Elsen
Thanks a lot for your answer.
It was not the response I was hoping for...
Thanks!
Joerg
