Speed connection only 65Mb
Anatoly Fanrus
could you help me,  i'm configuring a standalone AP 2602 with IOS 15.2.
When i connect to AP from my notebook i only get 65Mb speed, when i connect to other APs from the notebook my speed connection 150-300Mb.
What configuration(CLI) do i need to be able to connect to the AP on connection speed to 130-450Mb ? Currently I connect to SSID with WPA2 encryption and "speed default" on radio 0 interface.
Thank you
dot11 ssid TEST
  authen open
  authen key-management wpa "version 2"
  guest-mode
  infrastructure-ssid < not needed unless you are bridging>
  wpa-psk ascii 0 ******
In your SSID config you need to add 'version 2' in the authentication key-management line
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
7 Replies 7
Richard Atkin
Level 4
Level 4
It might be easier if you just paste the config / attach as a text file so people can take a look at the problem rather than just guessing.
ok,
dot11 ssid TEST
  authen open
  guest-mode
  infrastructure-ssid
bridge irb
interface Dot11radio0
  no ip address
  no ip route-cache
  ecnryption mode ciphers aes-ccm
  ssid TEST
  antenna gain 0
  stbc
  station-role root
  world-mode dot11d country-code RU indoor
  bridge-group 1
  bridge-group 1 subscriber-loop-control
  bridge-group 1 spanning-disabled
  bridge-group 1 block-unknown-source
  no bridge-group 1 source-learning
  no bridge-group 1 unicast-flooding
bridge 1 route ip
You're not helping.
This is all you've got in your config????
Sent from Cisco Technical Support Nintendo App
Post the entire Config please..
dot11 ssid TEST
  authen open
  guest-mode
HTH,
Steve
HTH,
Steve
I have a picture may be help you
Thank you so much, Steve!
