Wireless Traffic Generator
smamedov
Community Member
Hi , i would like to do some test with wireless QoS.
Is there any specific application (wireless traffic generator) for Windows 7 that sets up WMM UP values ?
Richard Atkin
Level 10
Level 10
This might not be quite what you're after, but you can configure Wireless QoS attributes on a PC via Active Directory... If memory serves, you can create per-Application configs which should do the trick for you?
Scott Fella
Here is how you can do it from a Windows 7 machine
http://www.biztechmagazine.com/article/2010/03/boost-network-performance-windows-7-qos
-Scott
