speed setting?
rrfield
Level 3
Level 3
I have two 1310 bridges, point to point, aprox 2.5 miles, clear line of sight. During heavy fog the link goes down and does not come back up.
I noticed the speed setting was set to
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
(speeds above 11.0 never worked so that's the highest I set the speed to)
I also see you can set the speed to just plain
1.0 2.0 5.5 11.0
What's the difference between the basic-<speed> setting and the setting without the basic- prefix?
Stephen Rodriguez
the "basic" speeds are the required speeds a client must support to be able to connect to the device. All others are considered "supported", meaning if we can negotiate to them, great! if not, then that's ok too.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
