Splash Page direct Problem
kebun
Community Member
Hi, i have problem with direct meraki to my own splash page. When user connect to Wifi, this page apear and when click Connect button, the page go to
ps://n70.network-auth.com/splash/?ac=ACB%3ABC%3A32%3A6D%3A1E&real_ip=10.1.35.32&client_ip=10.163.148.239&client_mac=E0:06:E6:7E:20:85&vap=1&a=b1d5781111d84f7b3fe45a0852e59758cd7a87e5&b=2470060&auth_version=5&key=f719a1fa18d1fa17b2053839d4ee2c6ec3d91d32&acl_ver=P5293445V2&continue_url=http%3A%2F%2Fwww.gstatic.com%2Fgenerate_204
I hope you guys can help me with this problem.
Thank You
jdsilva
Level 11
Level 11
I had this problem a few times with Chrome on a recent trip to Orlando. If I switch to *gasp* IE it works and I can get through the splash page. I never drilled into it to see what was causing it though.
simple818
Level 9
Level 9
I had this issue at one point and can't seem to remember what caused it. It's been a while. Maybe content filtering or how do you have these settings configured?
Adam R MS | CISSP, CISM, VCP, MCITP, CCNP, ITILv3, CMNO
If this was helpful click the Kudo button below
If my reply solved your issue, please mark it as a solution.
jdsilva
Level 11
Level 11
kebun
Community Member
Thank you guys @Philip D'Ath @simple818. Problem solved, just like @jdsilva said i use default browser like IE i can get through the splash page.
Philip D'Ath
Meraki Community All-Star
Is your custom splash page (hosted externally I am assuming) "whitelisted" so that users have permission to access it?
