SRE for NME-AIR-WLC6-K9 Wireless LAN Controller
tnayak
1) Does a NME-AIR-WLC6-K9  work with a Cisco 2911/k9 router
2) Would a used one include the SRE?
3) If not, can the SRE be purchased separately -what is the part number?
4) I want to add 1-2 access points (AIR-CAP3702i) to my home network - would I be better off getting a 2504 or 3504?
patoberli
I'm not sure about the module for your router, so can't answer that.
About your home network, do you already own the 3702i?
If your budget allows, get the newer 3504. Otherwise I'd get an 18x0 series with mobility express and use that one as a master. It's not as powerfull (configuration wise) as a 3504, but for a home network more than enough. The 3702i can then join it as subordinates. Here you find more information about this:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_cisco_mobility_express_8_8/b_cisco_mobility_express_8_8_chapter_00.html
patoberli
Thx!
