SSH and HTTPS on a Controller Interface
london.ism
I have a wireless controller 5508 and all my interfaces can be accessed via https or ssh from a wireless client.
Management access from a wireless client is disabled so I don't understand why this is happening.
Does anyone know how to fix this?
Elena
10 Replies 10
Scott Fella
Is management from dynamic interface also disabled? That has to issued from the CLI
-Scott
Hmmm...if it is not a gui option then probably not.
I'll have a go on the CLI.
No option on the GUI
config network mgmt-via-dynamic-interface enable|disable
-Scott
That didn't work I'm afraid. I have disabled the management via dynamic interface but it didn't do the trick.
The only way I can stop it is if I go to Management, under HTTP or Telnet-SSH in the GUI and disable it from there but then that cuts off the whole management access, including the service port.
Any other ideas?
Scott Fella
This only works of you are associated to an app on that WLC. If you are associated to an ap on WLC 1, you will be able access https or ssh to another WLC. This feature is only for the same WLC.
-Scott
I only have one controller on my network.
Scott Fella
You need to open up a TAC case then. I don't have that issue in any of my WLC's or in any of my installs. TAC can tell you ifs a bug or maybe a setting that is wrong.
-Scott
Do I need a support contract for that?
Yes you do.
I usually always leave managment via wireless enabled, but that only allows access to the management ip appdress of the WLC, not access to a dynamic interface ip address.  Again... I leave it enabled because I like to be able to access the WLC when I'm on a wireless device.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Good thread ..
I recently review this very topic. Although I didnt have a HTTPS issue, I had a SSH issue. ..
Read this document
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a7c988.shtml
Also note comment within the document about SSH
Remember that by design, even if management over wireless or dynamic interface is disabled, a device can still make an SSH connection to the controller. This is a CPU taxing task, and WLC limits the number of simultaneous sessions, and for how long using these parameters.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
