SSHv2 connection to AireOS WLC fails via Secure CRT
Muhammed Adnan
Level 4
Level 4
Hello All,
I am running with SecureCRT version 8.7.0.
While I try to do SSH via putty, it works fine for CIsco 8540WLC running on code 8.10.1120 but while I used secure CRT, it fails with below message:
SSHv2 to other devices works fine though.
Is there any way around this?
Leo Laohoo
5 Replies 5
marce1000
 - Possibly there is a  cipher-mismatch conflict whereby the Secure CRT does not support enhanced ciphers.                     Check for later version of Secure CRT, if available and applicable.
 M.
Scott Fella
I run the latest SecureCRT and also the beta's with no issues.  You should contact Vandyke as they are great to work with if the issue is with SecureCRT or not.
-Scott
Leo Laohoo
Great find Leo.
-Scott
Thank you Leo as always your response it helped :)
The moment I see notification of the response from you / Scott, I consider the problems as solved :)
