SSID and subnets
ricardorojas123
Level 7
Level 7
I can to have two SSIDs for all branch of my country, but each ones in a differents subnets,for example:
Area 1
SSID 1 : guest -> 192.168.1.1
SSID 2 : office -> 192.168.2.1
Area 2
SSID 1 : guest -> 192.168.3.1
SSID 2 : office -> 192.168.4.1
Area 3
SSID 1 : guest -> 192.168.5.1
SSID 2 : office -> 192.168.6.1
I have with a Wireless Lan Controller 4402 and version 4.
ankbhasi
Hi Friend,
If i get your question correct you want all your braches to have 2 SSIDs mapped to different subnets? If it is correct you can definetely achieve the same while creating dynamic interfaces and mapping them to the WLANS (SSIDs).
Have a look at this configuration guide which will guide you how to create interfaces and then map it to WLANs
http://www.cisco.com/univercd/cc/td/doc/product/wireless/control/c44/ccfig40/c40mint.htm#wp1114099
http://www.cisco.com/univercd/cc/td/doc/product/wireless/control/c44/ccfig40/c40wlan.htm#wp1089232
Ankur
*Pls rate all helpfull post
