04-01-2009 05:57 PM - edited 07-03-2021 05:24 PM
I have a NM WLC with four WLAN SSID and 8 APs, I want to broadcast the four SSID in 7 APs and just one SSID in one AP. Is ther a way to do that?
Thanks.
04-03-2009 06:34 PM
Unless you have a WCS and configured AP Group/HREAP Group via the WCS, you'll need to configure the AP Group/HREAP Group on all the WLC if you don't have a WCS.
04-20-2009 08:38 AM
Hello people, finally I opened a case with TAC and the answer was very simple:
In the Wireless Controller go to Wireless Option, then choose the AP that you want to restrict the SSID, then go to left panel option Radio and choose whether 802.11a/n or 802.11b/g/n. Then go to the right panel and put your mouse over the blue arrow that select your AP and a hide menu will appear, then choose configure and a new configuration screen apear where the option WLAN override exist. What you only need to do is enable this option and the list of all SSID that you want to active in this AP will appear. Once you select the SSID you need to apply and restar the AP.
Thanks all of you for your reply to this post.
