Disable 5Ghz Radio module in LAP1252AG
mperduca
I have a LAP1252AG-E-K9 managed by a WLC embedded in a Catalyst3750G. My question is the following: how can I disable the 5GHz radio module using the WLC (I desire leave only the 2.4GHz module). In addition : in case I put in the LAP only 3 2.4Ghz antennas the 5GHz module is automatically disable?
Thank you, Marco
Leo Laohoo
Physically remove the 5Ghz radio module.
Are you trying to disable 802.11a? If you are, go to Wireless 802.11a/n and under Network, un-tick 802.11a Network Status. Do the same to 802.11b/g/n.
Hope this is what you are looking for.
You should be able to go to the Wirless -> AP's -> Radios -> 802.11a/n AP's and choose to configure the AP. Once you are on the config screen, you can administratively disable the 802.11a/n radio on the 1250.
I haven't tested this but I beleive I've read that just disabling the radio via controller doesn't actually solve power problems- if you're trying to get full power to one 2.4 radio using just 15.4 watts, I believe you do have to physically uninstall the other radio.
If anyone can confirm otherwise, please post.
