ssid disappears
bluesea2010
Level 7
Level 7
Some devices do not see  some ssid SSID,(The SSID is running both 2.4 and 5 Ghz).
I have three SSID , sometimes the device cannot see the SSID intended to connect
what could be the issue
7 Replies 7
Mark Elsen
       - Perhaps the device(client)  is too far away from the access point(s) ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi @Mark Elsen
the device can see other SSID's from the same  AP ,but not all
        - How many SSID's are you broadcasting ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
Broadcase SSID is disabled?
AP in a different AP Group?
Scott Fella
Really hard to understand what you are saying. First off, what equipment do you have, model and firmware. How many aps do you have, do all client have that issue or just a few. What type of encryption are you using on each ssid?  Is there a specific ssid that is broken.
-Scott
Hi @Scott Fella
AIR-CT5760  , 03.06.05E
Total Ap's 275  .
do all client have that issue or just a few , few  clients reported
 What type of encryption are you using on each ssid  WPA2 encryption +AES
I´ve see this many time before related to authentication issue. If devices try to join the SSID too many times and fail on the authentication, it will be placed in a black list and SSID will desapear.
 If you are using AIROS, look at Client Summary, Excluded Clients.
Algo, run deboug with "debug client mac address" and share logs.
