SSID Monitoring ???
Sakthi vel
I want to Monitor the SSID which configured in WLC
Is there any tool or plugin available for WCS or else For nagios.
Please help me on this.
Nitzbegin
Hi Sakthi,
I dont think we can monitor SSID , As this is one of the entity/config through which the Wifi users will communicate inorder to access their network.
Also this is shown natively by the WCS (Users -> SSIDs). So there is not point in monitoring the SSID in specific if you have WCS in place,
Basically SSID's nothing but Configuration tat helps client devices distinguish between multiple wireless networks
So basically Multiple networks = Multiple SSID's
Nithin
Amjad Abdullah
What type of monitoring that you want?
on WCS I have a configuraiton to show me graphs of number of clients per SSID. Also you can set graphs for bandwidth consumption per SSID.
Is that what you are looking for?
Amjad
Rating useful replies is more useful than saying "Thank you"
Abhishek Abhishek
Hello Sakthi,
As per your query i can suggest you the following solution-
To Monitor the SSID which configured in WLC
Monitoring the Status of Per-WLAN RADIUS Source Support
To see if the feature is enabled or disabled, enter the following command:
show wlan wlan-id
Example
The following example shows that the per-WLAN RADIUS source support is enabled on WLAN 1.
show wlan 1
For more information refer the link-
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html#wp1432232
Leo Laohoo
I think I know what you are looking for ... If you have WLC, load firmware 7.4.100.X and enable AVC.
