SSID not broadcasting properly
Hi Team,
We have 2800 APs with FRA enabled as auto. We are seeing all SSIDs not broadcasting on all APs all time. Its intermittent. Because of that user connect with AP which is far instead of nearby AP.
Any specific reason for that.
We have AP group creation where we have call all WLAN.
8 Replies 8
Sandeep Choudhary
Clinet decide To join which AP and/or which radio not AP or WLC. If the wireless client wants to associate to the furthest AP then there's nothing you can do.
There are ways to to minimize it..1. your wireless clients are running the latest drivers.
2. On the AP-side, you could also try to disable the low-speed data rates (disable 802.11b, make 18 Mbps as Mandatory and the rest are Supported).
Dont forgetto rate helpful posts
Hi @Sandeep Choudhary
Thanks for reply.
Issue here is sometime AP broadcast some SSID and some time its not broadcasting. Connection of client to any AP, we are fine it depend on client adapter, but AP should broadcast all SSID configured in that AP group
vivek NAGAR
Frequent Visitor
Frequent Visitor
Please check if the AP advertise the SSID's or not
On WLC check below
show ap wlan 802.11a "AP NAME"
show ap wlan 802.11b "AP NAME"
this will show you Site  Name and WLAN ID numbers which advertise via AP
Vivek
Hi @vivek NAGAR
Its intermittent. Given command gives all configured WLAN broadcasted. Sometime its not broadcasting. ANy specific reason for that
Leo Laohoo
Can you replicate this issue?
Hi @Leo Laohoo
Its intermittent. We can replicate. What you require
Show me the complete output to the command "sh client detail <MAC ADDRESS>".
when you are not seeing the SSID on client machine that time can you check the AP broadcast SSID or not via same command,
