SSID Per WLAN
seth.jones
Community Member
Hello Everyone,
Is there a doc available for setting up multple WLANs, with having each wlan on its own vlan?
THanks
Equipment:
2106 WLAN Controll
Aironet 3502 AP
Peter Nugent
Here you go Seth, if you have any specific queries as you go on don't hesitate to use the forum.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805e7a24.shtml
Yes, this seems easy enough. However, I am having issues with the dhcp.  I am attempting to do this with dual ISPs.  The secondary interface sends out the dhcp broadcast, but does not get a response.
If I am trying to run directly out of the WLAN Controller to the ISP switch, is there anything specific I would need to do?  I am still not able to get this to function properly.
Amjad Abdullah
You careate logical interfaces on the WLC, right? (Controller -> Interfaces). and those interfaces are mapped to WLANs.
what you need to do is simply choose the interface (which determines the VLAN) from the WLAN that you create. This way your WLAN is mapped to an interface which maps it to a VLAN.
You'll find Peter's link very useful (+5 Peter).
Amjad
Rating useful replies is more useful than saying "Thank you"
