SSID with PSK not allowing clients to reconnect
seghettia
I have a 2504 that has 2 SSID's configured. 1 SSID is corp and has WPA2-PSK enbabled and works just fine.  SSID 2 is guest and I would like to lock it down with a WPA2-PSK.  This works fine for 24hours then the clients that have been connected to SSID 2 can no longer connect.  I have had a laptop, an Android phone, Ipad 2, and an Iphone all get kicked off SSID 2 after 24 hours. Even if I put the correct password in they can't connect to SSID 2 I end up resetting the password and then it happens again the next day. Any thoughts?
Leo Laohoo
Duplicate post.
Go here:  https://supportforums.cisco.com/discussion/12222096/ssid-psk-not-allowing-clients-reconnect
