SSID WPA Parameters - CCMP256
rmfalconer
Is anyone using the parameter for CCMP256 on any SSIDs?
Are Wave 2 APs needed or is Wave 1 fine? Issues with client NICs or drivers? Iphone/Android support?
Thanks.
patoberli
Never used it. I also can't answer any questions regarding compatibility.
I only found this: https://content.cisco.com/chapter.sjs?uri=%2Fsearchable%2Fchapter%2Fcontent%2Fdam%2Fen%2Fus%2Ftd%2Fdocs%2Fwireless%2Fcontroller%2Frelease%2Fnotes%2Fcrn83mr1.html.xml&platform=Cisco%20Wireless%20LAN%20Controller%20Software
As far as I know, CCMP-256 and GCMP-256 are only supported on 802.11ac adapters. Once it's enabled, older adapters can't anymore connect.
Some more info: https://community.spiceworks.com/topic/2118884-aes-vs-aes-ccmp-vs-aes-gcmp-on-enterprise-wifi
