stand alone access point
i configure Air-ap1252Ag-a-k9 i create ssid but the ssid is not showing in laptop
Rasika Nayanajith
Hi Syed,
See whether you have configure "ssid guest mode" configured under SSID. Post your "show run config" to see what's missing on your config
Rasika
ap#terminal l
ap#terminal length 0
ap#sh ru
ap#sh running-config
Building configuration...
Current configuration : 1692 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$8XVY$akpecnOxxa3Vl.LgRINJz.
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.10
ip dhcp excluded-address 192.168.1.254
ip dhcp pool wireless
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
   lease 15
dot11 ssid test1
   authentication open
   guest-mode
power inline negotiation prestandard source
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid test1
dfs band 3 block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid test1
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.1.10 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
sh run                  ter
ap#terminal l
ap#sh ru
version 12.4
no service pad
hostname ap
no aaa new-model
   lease 15
dot11 ssid test1
   authentication open
   guest-mode
bridge irb
no ip address
no ip route-cache
ssid test1
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
shutdown
ssid test1
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
then change to
login local
end
after that make  changes
no sh
now it  is working
when i m doing for gui mode its not working .through cli cmd its working
for every ssid we type this  cmd
dot11 ssid test1
   authentication open
   guest-mode
harvisin
Level 5
Level 5
Hello Syed,
Please paste your running configuration over here so that we can verify it .
