Static IP allowed in Wireless Controller.
karinn001
Level 2
Level 2
I have wireless controller 2505 and i want to give static IP from the Pool to some users and make sure users are always login with same IP address every time its login
Rasika Nayanajith
Are you using 2504 as the DHCP server for those client ? If so this is not possible.
Otherwise, if you have seperate DHCP server, you can reserve IP address for given client MAC and allow static IP client to join given SSID. That will do.
Rasika
*** Pls rate all useful responses ****
Rasika Nayanajith
Rasika
Hi Rasika,
Issue has resolved by using your method.
