Strange WLC console reports
winkelu
Hello any idea what my WLC is reporting?
see attachment
5 Replies 5
Scott Fella
How many AP's do you have up on the WLC currently and are you only having issues with the ones that show up in the log?  What WLC do you have, what code and what AP's?
-Scott
I have 8 AP´s and the WLC is a 5508 with  V7.0.98.0
I am not super sure about whats happening but it appears that the APs are losing keepalives from the controller and hence dropping off ... again i will have to look it up... can you tell me what is the topology? are the APs trying to connect to the WLC over WAN?
What is your console logging level set too?  The WLC tends to be very verbose with messages if you are set to a lower levle.  If it's causing issues, I'd start with upgrading to 7.0.22.0
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
request can be closed,
it was a missbehavior of the WLC,
after receiving a new one everything was OK!
