Stuck with Repeater on AIR-CAP2702i
tomnick
Hi everybody, I am trying to use one AIR-CAP2702i as an AP and another one as a repeater. The AP works like a charme but trying to login into the repeater with e.g. a smartphone ends with :
Interface Dot11Radio1, Station fe40.54b0.b45c Associated KEY_MGMT[WPAv2 PSK]
Interface Dot11Radio1, Deauthenticating Station fe40.54b0.b45c Reason: Previous authentication no longer valid
Packet to client fe40.54b0.b45c reached max retries, removing the client
and getting no IP.  I already changed "Max. Data retries" to 128 but no affect at all. Any ideas what might could be wrong? Thanks for some help.
Product/Model Number:AIR-CAP2702I-E-K9
 Top Assembly Serial Number:FCW1917NCEK
 System Software Filename:ap3g2-k9w7-xx.153-3.JI5
 System Software Version:15.3(3)JI5
 Bootloader Version:BOOTLDR: C2700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB5m, RELEASE SOFTWARE (fc2)
Rich R
Does the smartphone connect ok to the same SSID on the other AP?
Is the SSID configured identically on both APs?
We'd probably need to see the full config (show run) for both APs to have a better chance of identifying any issues in the config as it's not possible to guess from a few screenshots.
Config of AP:
! Last configuration change at 01:01:55 +0100 Wed Mar 3 1993
version 15.3
no service pad
service password-encryption
hostname AIR-CAP2702i-E-K9
logging rate-limit console 9
enable password 7 0005170B0D55
no aaa new-model
clock timezone +0100 1 0
no ip source-route
no ip cef
dot11 pause-time 100
dot11 syslog
dot11 vlan-name Home vlan 1
dot11 vlan-name IOT vlan 45
dot11 ssid Home
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   infrastructure-ssid
   wpa-psk ascii 7 0211015206071D20424B1B4B545A425E41567A7B7D6D
dot11 ssid IoT
   vlan 45
   authentication open
   guest-mode
   wpa-psk ascii 7 020F0B4F111308204249
no ipv6 cef
username admin privilege 15 password 7 15010E00102F3975786370
bridge irb
interface Dot11Radio0
 no ip address
 encryption mode ciphers aes-ccm tkip
 encryption vlan 45 mode ciphers aes-ccm
 ssid IoT
 antenna gain 0
 stbc
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.45
 encapsulation dot1Q 45
 bridge-group 45
 bridge-group 45 subscriber-loop-control
 bridge-group 45 spanning-disabled
 bridge-group 45 block-unknown-source
 no bridge-group 45 source-learning
 no bridge-group 45 unicast-flooding
interface Dot11Radio0.451
interface Dot11Radio1
 no ip address
 encryption vlan 1 mode ciphers aes-ccm
 ssid Home
 antenna gain 0
 peakdetect
 no dfs band block
 stbc
 speed  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss9 a2ss8 a3ss9
 packet retries 128
 channel dfs
 station-role root
interface Dot11Radio1.1
 encapsulation dot1Q 1 native
 bridge-group 1
interface Dot11Radio1.11
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0.1
 bridge-group 1
interface GigabitEthernet0.11
interface GigabitEthernet0.45
 bridge-group 45
interface GigabitEthernet0.451
interface GigabitEthernet1
 no ip address
 shutdown
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 mac-address 5897.bdf3.6328
 ip address 192.168.1.176 255.255.255.0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
Config of Repeater:
! Last configuration change at 00:27:31 UTC Mon Mar 1 1993
version 15.3
no service pad
hostname ap1
enable secret 5 $1$kqL7$C0iGzeoBGlUBFJ8K7MWl/0
no aaa new-model
no ip source-route
no ip cef
dot11 syslog
dot11 ssid Home
   vlan 1
   authentication open
   guest-mode
   infrastructure-ssid
   wpa-psk ascii 7 0718244543080B041917195E55677B71656165724A42
no ipv6 cef
username Cisco password 7 106D000A0618
bridge irb
 no ip address
 shutdown
 antenna gain 0
 station-role root
 bridge-group 1
 no ip address
 ssid Home
 antenna gain 0
 peakdetect
 stbc
 speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss9 a2ss8 a3ss9
 packet retries 128
 station-role repeater
 bridge-group 1
 no ip address
 duplex auto
 speed auto
 bridge-group 1
 no ip address
 shutdown
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 mac-address a46c.2a88.e3e0
 ip address 192.168.1.85 255.255.255.0
 ipv6 address dhcp
 ipv6 enable
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
