Supposed signal distance for AIR-ANT2566P4W-R
marek.golha
is there somewhere a documment that describes something like supposed distance which the wireless signal can reach when using for example AIR-ANT2566P4W-R? I need to know if I can use this antenna together with 2600 AP to create a point to point wireless link between two buildings when the distance between buildings is 200m...
Thank you.
Marek
Stephen Rodriguez
I've not seen a document that shows the distance that you can cover with that antenna, it would vary depending on the power level you were using with it.
From what I've seen of that antenna though, I would think you would be able to use it to bridge 200m, if you had them on both sides and had them aligned properly. you will need to be careful of the backlobe of that antenna.
http://wifijan.us/1fOQSa4
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Hello Steve,
thanks for sharing your experience. Nice blog - that is something for my RSS  reader.
Thank you.
Marek
Abhishek Abhishek
I have never been able to see the below scenario being implemented.
