5508 HA and DTLS
sniff
i have a 5508 HA cluster with different software.
Primary          AIR-CT5500-K9-7-6-110-0.aes
Secondary     AIR-CT5500-LDPE-K9-7-6-110-0.aes and a 6.x FUS
is it possible to change the secondary to AIR-CT5500-K9-7-6-110-0.aes and FUS 1.9.0.0 ?
Regards Sven
2 Accepted Solutions
Scott Fella
Well it's a good idea to first convert the LDPE to a non- LDPE, then you can of course upgrade the FUS to v1.9.0.0.  Take a look at this document as the license is free.
https://supportforums.cisco.com/document/102681/converting-ldpe-controller-image-non-ldpe
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
-Scott
No... You need to do this before enabling AP SSO. You now need to disable AP SSO and add the license to the backup and also upgrade the FUS. Then you can enable AP SSO again.
Scotty
-Scott
5 Replies 5
Scott Fella
Scotty
-Scott
The LDPE is on the secondary HA and there is no command to add the license.
Is it possible to install the license over CLI, the primary or after a restart with escape the boot-secuence?
Scotty
-Scott
Hello Scotty,
sorry for my very late answer, rebooting after disable AP SSO was the reason.
After rebooting it was still impossible to install the license because the lack of the gui "install license" command on secondary (stupit, i forgot to try it over cli)
I cleared the config ( no HA) installed the license, FUS and Firmware (without LDPE).
After rebooting I started with a new secondary installation and everything works fine, now.
Thanks for your help
Sven
Abhishek Abhishek
No, as per the scenario it is not possible to change the secondary to AIR-CT5500-K9-7-6-110-0.aes and FUS 1.9.0.0.
