Survey Mode
Paul2469
Community Member
I connect a new MR30H out of the box to my home router, this then allowed me to access the local AP and set to survey mode. However, the power and channels will not change, if i change them, click save and refresh the page, they are still in default mode. to make matters worse the AP is not broadcasting any 5Ghz SSID. Please advise, do i need to connect to Meraki dashboard or ?
Ya definitely let it connect to the cloud, make sure your running 25.13 code and then follow the guide mentioned above.
BrechtSchamp
Level 11
Level 11
I'm not sure if it matters but did you claim it into an organisation, assign it to a network and check-in at least once?
Ensure that the AP has come online and checked into the Cisco Meraki Cloud Controller at least once. It should currently be green in Dashboard.
Source: https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Conducting_Site_Surveys_with_MR_Access_Points
I connected the AP to my home router to give it internet access, but i did not have meraki cloud dashboard access at the time. So i assume i need to try and get the AP back online and then i can sort out my issues.
Nick16
Level 6
Level 6
Hi Paul,
Did you follow the guide and allow the AP to connect to the cloud initially?
The guide here has a few gotcha's linked to the connectivity on the AP check it out, if you still have no joy let us know
EDIT - Got beaten to the punch! This is what happens when you make coffee!
