Switch configuration for LAPs
JASON SIMMONS
Level 5
Level 5
A local mode LAP is broadcasting WLANs that use VLAN10, VLAN20, and VLAN30.  The switchport the LAP is connected to is configured in access mode.  Do VLANs 10, 20 & 30, need to be configured on the switch?
Sandeep Choudhary
No,
You need to configure the WLC port as trunk and allow these vlan to this port.
Example:
WLC:
interface GigabitEthernet1/0/1
description Trunk Port to Cisco WLC
switchport trunk allowed vlan 10,20,30
switchport mode trunk
AP:
interface GigabitEthernet1/0/22
description Access Port Connection to Cisco Lightweight AP
switchport access vlan 10 ------> in which vlan AP getting ip
switchport mode access
no shutdown
Dont forget to rate helpful posts
Sandeep Choudhary
No,
Example:
WLC:
AP:
no shutdown
I thought so.  I just wanted to run it by you gurus to make sure my thinking was correct.
Just to add, below are some additional best practice config lines for those ports if you are concern about QoS & STP convergence
--- WLC Trunk Port -----
mls qos trust cos
spanning-tree portfast trunk
--- AP access Port -----
mls qos trust dscp
Rasika
**** Pls rate all useful responses ****
