Syslog Configuration for WLC 2504
usman_safdar
Hi everyone,
                          I am new to syslog world, i intend to see following in my syslog server
- Who logged into WLC and when logged out
- Changes made in the configuration of WLC
For time being my config at WLC is
Syslog Server Ip : xx.xx.xx.xx
Syslog Level -->Notifications
Syslog Facility --> Local use 0
Buffered log Level --> Errors
Console Log Level --> Disable
File info Ticked
Trace info Ticked
Any help shall be highly appreciated.
Mark Elsen
 - Not possible on the older aireos based controllers such as the 2504 , you can do that on the 9800 platform with IOS XE  , for instance : https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/config-mgmt/configuration/xe-3se/wlc5700/config-mgmt-xe-3se-wlc5700-book/cm-config-logger.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Scott Fella
What can help you get that visibility is using Cisco ISE for TACACS.  A TACACS server can provide that information and also what commands were ran by that user.  Plus with TACACS, you have the ability to allow certain groups or commands to be executed which is nice to have by being able to build rules for device access.
-Scott
Rich R
The correct way to do this is with TACACS, not syslog, as per what Scott said above.
