Test 9800-CL Wireless Controller setup and configuration as a third controller
Group IT
Level 3
Level 3
Hi All,
I thought I was getting to grips with the wireless world but I am finding that I am a little out of my depth setting up a test Cisco Catalyst 9800-CL Wireless Controller.
This will be my third controller, this one I am testing in a VMWare ESXi environment which sits on my live network.
So I have controller one at our HQ "CISCO-CAPWAP-CONTROLLER" is on 10.11.0.230, controller two is in a datacentre "CISCO-CAPWAP-CONTROLLER" and is on 10.11.202.230. I have introduced controller three which is the test 9800-CL Wireless Controller at our HQ also "CISCO-CAPWAP-CONTROLLER" and is on IP 10.11.0.199.
I have a test C9120AXI-E which is plugged into a trunked port. Quite rightly so, the older controllers are rejecting it, but it never seems to attempt to connect to the 9800-CL. It seems to just repeat the following process:
 CAPWAP State: Discovery
[*10/23/2019 14:04:17.6470] IP DNS query for CISCO-CAPWAP-CONTROLLER.mydomain.local
[*10/23/2019 14:04:17.6500] DNS resolved CISCO-CAPWAP-CONTROLLER.mydomain.local
[*10/23/2019 14:04:17.6500] DNS discover IP addr: 10.11.0.199
[*10/23/2019 14:04:17.6500] DNS discover IP addr: 10.11.0.230
[*10/23/2019 14:04:17.6500] DNS discover IP addr: 10.11.202.230
[*10/23/2019 14:04:17.6510] Discovery Request sent to 10.11.0.199, discovery type DNS(3)
[*10/23/2019 14:04:17.6520] Discovery Request sent to 10.11.202.230, discovery type DNS(3)
[*10/23/2019 14:04:17.6530] Discovery Request sent to 10.11.0.230, discovery type DNS(3)
[*10/23/2019 14:04:17.6540] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*10/23/2019 14:04:17.6560] Discovery Response from 10.11.0.230
[*10/23/2019 14:04:17.6610] Discovery response from MWAR 'wlc-h003214' running version 8.5.151.0 is rejected.
[*10/23/2019 14:04:17.6610] Failed to decode discovery response(status = 4).
[*10/23/2019 14:04:17.6610] CAPWAP SM handler: Failed to process message type 2 state 2.
[*10/23/2019 14:04:17.6610] Failed to handle capwap control message from controller - status 4
[*10/23/2019 14:04:17.6610] Failed to process unencrypted capwap packet 0x55a0066000 from 10.11.0.230
[*10/23/2019 14:04:17.6610] Failed to send message to CAPWAP state machine, msgId 0
[*10/23/2019 14:04:17.6610] Failed to send capwap message 0 to the state machine. Packet already freed.
[*10/23/2019 14:04:17.6610] IPv4 wtpProcessPacketFromSocket returned 4
[*10/23/2019 14:04:17.6620] Discovery Response from 10.11.202.230
[*10/23/2019 14:04:17.6650] Discovery response from MWAR 'wlc-h000453' running version 8.5.151.0 is rejected.
[*10/23/2019 14:04:17.6650] Failed to decode discovery response(status = 4).
[*10/23/2019 14:04:17.6650] CAPWAP SM handler: Failed to process message type 2 state 2.
[*10/23/2019 14:04:17.6650] Failed to handle capwap control message from controller - status 4
[*10/23/2019 14:04:17.6650] Failed to process unencrypted capwap packet 0x55a0064000 from 10.11.202.230
[*10/23/2019 14:04:17.6650] Failed to send message to CAPWAP state machine, msgId 0
[*10/23/2019 14:04:17.6650] Failed to send capwap message 0 to the state machine. Packet already freed.
[*10/23/2019 14:04:17.6650] IPv4 wtpProcessPacketFromSocket returned 4
So from what I can see, DNS is configured correctly so that the AP can see all of the available controllers but I doesn't seem to be requesting to join the 9800-CL.
Can anyone advise what step I have missed or where I can check whats going wrong?
Thanks in advance.
MrDude
Frequent Visitor
Frequent Visitor
Can you check the wireless management trustpoint?
show wireless management trustpoint
It should look something like:
Trustpoint Name : CISCO_IDEVID_SUDI
Certificate Info : Available
Certificate Type : MIC
Private key Info : Available
FIPS suitability : Not Applicable
If this isn't the case you can generate it with: wireless config vwlc-ssc key-size 2048 signature-algo sha256 password ThisisaPassword01
Hi Mr Dude,
Thanks for the suggestion. I ran the command as you suggested and indeed I do not have any Trustpoint listed. However, I can't seem to get the controller into config mode. Config t. conf t. doesn't seem to work and enable isn't accepted either. I tried to run it and got the following:
v000002>wireless config vwlc-ssc key-size 2048 signature-algo sha256 password superpassword
% Invalid input detected at '^' marker.
Am I doing something really silly?
Thanks.
MrDude
Frequent Visitor
Frequent Visitor
Hi, it looks like you need to go in to enable mode first. You shouldn't have to go in to configuration terminal to run the command.
Hey sorry! I have only just got back round to taking a look at this.
I think the problem was the the command to generate certificate had not specified an encryption level but still after it does not report any trustpoint.
wireless config vwlc-ssc key-size 2048 signature-algo sha256 password 7 ThisisaPassword0
wlc>show wireless management trustpoint
Trustpoint Name :
Certificate Info : Not Available
Private key Info : Not Available
