TFTP
akbar1
Community Member
I have deployed 14 cisco 1242 AP in 14 different locations all are working fine , now i need to deploy one additonal AP at each location , so i copied the running config via TFTP server now when i try to copy the config from TFTP sever to the new AP i get error on the TFTP serevr as timoeut error for 2 to 3 times & on the fourt time the config is copied on to the AP , i logged on to AP via telnet & cheched the config & it was fine but when i use the browser i cannot connect to AP on the console of the AP i get this error ''CRYPTO_PKI: Can not select private key (TP-self-signed-3340 435852)''
Not applicable
The command " 'ip http secure-server" should be added.Open a new Internet Explorer window and go under Tools |
Internet Options | Advanced | Security | Allow active content to run in files on My Computer.Make sure this option is enabled.Tried it in another computer.
