the GUI of 9100 embedded WLC does not load in different browsers
atifali.zaidi1
Hello Experts, i had converted a 9120 ap into embedded 9800 WLC using https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html  but after doing when i try to do https or http to the management IP it presents the login window, and i can login successfully but after that it tries to load the page and stops. when i try to refresh the page , still the same problem. i have also tried chrome and mozilla and the same problem exists.
tried another computer , still the same problem.
i am located in India and the wlc is in UK if that makes a difference.
10 Replies 10
Rasika Nayanajith
Once you converted to EWC, WLC functionality within AP. So there is no dependency on where is your 9800 WLC.
What IOS-XE version are you using? I would suggest 17.3.2a if your software is not that
Rasika
atifali.zaidi1
i had applied 17.4.01 initially , so you are saying that i should downgrade to 17.3.2a then ?
I am not sure whether 17.3.2a will fix your issue, however code train perspective, stay in 17.3.x would be advisable as it is an extended-release, so you will get maintenance updates like 17.3.3, 17.3.4, etc.
17.4.1 is a standard release and will not have any maintenance update on that code version, it is really if you looking for new features that are not available on 17.3.x
Rasika
this is test lab setup for documentation purposes , so if i downgrade to 17.3.2a then i need to download the 9120 software bundle for it , right ?  i am attaching a screenshot for it.
and one last thing , i dont have any licenses purchased for it . so if evaluation licenses are not available in 17.3 train as you mentioned in my other post , then why should i do ?
You do not require a licence to purchase anyway. With 17.3.x there is an evaluation licence and it works once you activate it. Even eval licence expired, still, your EWC will work.
With 17.4.x Cisco trying to further streamline this process and not require activation of eval licences.
If you tried different browsers and possibly from different devices and you encounter the same problem, then worth downgrade & see if that fix your issue. Licencing part is a convenience measure and not impacting the functionality of EWC
Refer below for EWC software upgrade workflow
https://www.cisco.com/c/dam/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/ewc-sw-workflow.pdf
Rasika
*** Pls rate all useful responses ***
- Clear all cookies
- Try running browser in private/incognito mode
- The page is very slow to load first time - especially over slow connection so give it a few minutes at least.
I tried your suggestion and when using Google Chrome the login prompt appears and accepts the credentials but the page never fully loads.  Below is the console output from the Chrome performance log on a C9800 I have in lab.  Has anyone experience the login working but the page never fully loading?
3switch.css:1 Failed to load resource: the server responded with a status of 404 (Not Found)
kendo.all.min.js:1 Failed to load resource: net::ERR_CONTENT_LENGTH_MISMATCH
angular-kendo.js:800 Uncaught ReferenceError: kendo is not defined
at angular-kendo.js:800
at angular-kendo.js:2
at angular-kendo.js:3
(anonymous) @ angular-kendo.js:800
(anonymous) @ angular-kendo.js:2
(anonymous) @ angular-kendo.js:3
btrace_eventq_db_js.js:1 Failed to load resource: net::ERR_CONTENT_LENGTH_MISMATCH
atfStatisticsController.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
licenseGeneralCtrl.js:1 Failed to load resource: net::ERR_CONTENT_LENGTH_MISMATCH
locationConfigurationService.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
wlanConfigController.js:1 Failed to load resource: net::ERR_CONTENT_LENGTH_MISMATCH
stealthwatchService.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
stealthwatchController.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
reportingCtrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
atfConfigController.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
switchService.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
dayzeroController.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
step1Ctrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
step2Ctrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
step3Ctrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
step4Ctrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
step6Ctrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
step7Ctrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
step8Ctrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
step5Ctrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
switchwide.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
summaryScreenCtrl.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
leftTabsController.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
switchController.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
d3-hierarchy.v1.min.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
mrpRingDirective.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
migrationHelperService.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
apJoinController.js:1 Failed to load resource: net::ERR_CONTENT_LENGTH_MISMATCH
ewlc_common_js.js:1 Failed to load resource: net::ERR_CONTENT_LENGTH_MISMATCH
ewlc_green_config_db_js.js:579 Uncaught ReferenceError: dispatch_message_ewlc_config_oper is not defined
at ewlc_green_config_db_js.js:579
(anonymous) @ ewlc_green_config_db_js.js:579
ewlc_green_oper_alt_db_js.js:269 Uncaught ReferenceError: dispatch_message_ewlc_config_oper is not defined
at ewlc_green_oper_alt_db_js.js:269
(anonymous) @ ewlc_green_oper_alt_db_js.js:269
ewlc_green_oper_db_js.js:763 Uncaught ReferenceError: dispatch_message_ewlc_config_oper is not defined
at ewlc_green_oper_db_js.js:763
(anonymous) @ ewlc_green_oper_db_js.js:763
ewlc_green_oper_emul_db_js.js:445 Uncaught ReferenceError: dispatch_message_ewlc_config_oper is not defined
at ewlc_green_oper_emul_db_js.js:445
(anonymous) @ ewlc_green_oper_emul_db_js.js:445
x.x.x.10/:500 GET https://x.x.x.10/webui/features/locationConfiguration/locationConfigurationService.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:538 GET https://x.x.x.10/webui/features/threatDefense/stealthwatchService.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:539 GET https://x.x.x.10/webui/features/threatDefense/stealthwatchController.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:612 GET https://x.x.x.10/webui/features/softwareActivation/reportingCtrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:617 GET https://x.x.x.10/webui/features/atf/atfConfigController.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:618 GET https://x.x.x.10/webui/features/atf/atfStatisticsController.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:619 GET https://x.x.x.10/webui/features/switchView/switchService.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:628 GET https://x.x.x.10/webui/features/dayzero/dayzeroController.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:629 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/step1Ctrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:630 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/step2Ctrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:631 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/step3Ctrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:632 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/step4Ctrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:633 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/step5Ctrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:634 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/step6Ctrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:635 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/step7Ctrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:636 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/step8Ctrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:637 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/switchwide.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:638 GET https://x.x.x.10/webui/features/dayzero/StepCtrls/summaryScreenCtrl.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:639 GET https://x.x.x.10/webui/features/dayzero/leftTabsController.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:641 GET https://x.x.x.10/webui/features/switchView/switchController.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:642 GET https://x.x.x.10/webui/lib/d3/d3-hierarchy.v1.min.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:643 GET https://x.x.x.10/webui/features/mrpMonitor/mrpRingDirective.js net::ERR_ABORTED 404 (Not Found)
x.x.x.10/:644 GET https://x.x.x.10/webui/common/services/migrationHelperService.js net::ERR_ABORTED 404 (Not Found)
main-es2015.js:1 ng2 loaded!!!!
angular.js:38 Uncaught Error: [$injector:modulerr] http://errors.angularjs.org/1.5.5/$injector/modulerr?p0=%24%24UpgradeModule&p1=Error%3A%20%5B%24injector%3Amodulerr%5D%20http%3A%2F%2Ferrors.angularjs.org%2F1.5.5%2F%24injector%2Fmodulerr%3Fp0%3DwebUiDevApp%26p1%3DError%253A%2520%255B%2524injector%25...)
at angular.js:38
at angular.js:4587
at q (angular.js:322)
at g (angular.js:4548)
at bb (angular.js:4470)
at c (angular.js:1746)
at Object.yc [as bootstrap] (angular.js:1767)
at main-es2015.js:1
at main-es2015.js:1
at a.invoke (polyfills-es2015.js:1)
(anonymous) @ angular.js:38
(anonymous) @ angular.js:4587
q @ angular.js:322
g @ angular.js:4548
bb @ angular.js:4470
c @ angular.js:1746
yc @ angular.js:1767
(anonymous) @ main-es2015.js:1
invoke @ polyfills-es2015.js:1
onInvoke @ main-es2015.js:1
run @ polyfills-es2015.js:1
run @ main-es2015.js:1
bootstrap @ main-es2015.js:1
o @ main-es2015.js:1
To @ main-es2015.js:1
Zo @ main-es2015.js:1
Go @ main-es2015.js:1
create @ main-es2015.js:1
bootstrapModuleFactory @ main-es2015.js:1
zUnb @ main-es2015.js:1
i @ runtime-es2015.js:1
0 @ main-es2015.js:1
t @ runtime-es2015.js:1
r @ runtime-es2015.js:1
Show 6 more frames
That suggests files are missing are have wrong permissions set.  I would re-install software.
17.5.1 is out now - give that a try.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-5/config-guide/ewc_cg_17_5.html
And have you tried connecting to it locally (or got somebody local to try)?  Just wondering if it's something to do with not being on the same subnet?
