Three AP with same ssid. create a ssid of Guest
network-Raj
We have three AP 1852i. configured in mobility express with same ssid. now we need one ssid  guest id.
one is working as primary and other two are working as secondary. But we have not configured as primary and secondary any ap.
Please suggest how can we configured the new  ssid guest in one ap.
regards
raj
marce1000
 - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-7/b_cisco_mobility_express_8_7/b_cisco_mobility_express_8_7_chapter_0110.html#task_D233A7F08DE340B3AA05C4CAA08FE49B
 M.
Sandeep Choudhary
Are these APs are working separately ? or one AP as main WLC and controlling the rest APs ?
Best would be to create a new SSID in AP which are working as WLC and assign this ssid in a different AP group.
Dont forget to rate helpful posts
If you are using as
balaji.bandi
If your setup already running with other SSID you need to add only new SSID for Guest.
You need to make a different Group - since you looking to only broadcast only for AP ( so that will be based on the Group)
Then create a SSID as per below document
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-6/b_cisco_mobility_express_8_6/b_cisco_mobility_express_8_6_chapter_0111.html
Once the new SSID created - add that to new Group (part of that AP you looking to broadcast) - i am sure you looking to have other SSID also to be served along with new Guest SSID. - so you need to add all SSID to that group, so Only that  desired AP will have new SSID and OLD SSID broadcast, another AP only current SSID will be there.,
AP Groups - above document covers how to make groups.
BB
