Throughput oid wlc WLAN
loffreda
Frequent Visitor
Frequent Visitor
Hi team ,
somewhere know the OID record to monitoring the traffic SNMP or had experiences with this specific OID Throughput wlc by  WLAN because surf on the internet I found some link with tree reference code and spend a lot of time navigate on tree OID but I ' haven't found anything interesting for my issu.
I need it to perform my monitoring system.
Thanks ,
balaji.bandi
WLAN ( you means per SSID ?)
Are you using Prime, then you can browse Dashboard / performance - site, give you each SSID usage
here is solarwinds output :
https://thwack.solarwinds.com/ideas/4429
BB
Hi BB ,
yes I means SSID , we using daily basic but cisco Prime is heated but my client , so we monitoring all devices with PRTG is very reliable. I' m adding all my sensor on this I find the OID for temperatures , joined AP ecc but not Throughput , we would like to have a sensor Throughput by SSID. If you never used it , I recommennd it.
