Cisco Wireless Controller Config
HassanAldaher
Community Member
Hallo,
I want to configure cisco wireless Controller using Packet Tracer.
I have configured 2 Vlans(OFFICE , PRODUKT) on 3Layer Switch.
VLAN 10
OFFICE
192.168.10.1
VLAN20
PRODUKT
192.168.20.1
DHCP Pools for Vlans have configured
LWAP have conneted to port 4(access port on vlan10)
LWAP have conneted to port 5(access port on vlan 20)
What must the Configuration on WLC (management IP:192.168.1.254 on default vlan) to join the Access points?
Mark Elsen
  - You dont' configure a controller with a packet tracer. The latter is a tool for analyzing network packets. Wireless controller configuration tutorial is find below (that is only an example link). For in-depth knowledge consult the CISCO documentation (configuration guides).
                   https://www.youtube.com/watch?v=RzZCu-_6Q1k&gl=BE
 M/
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I suspect Hassan might be talking about https://www.netacad.com/courses/packet-tracer which is a networking simulator used in Cisco training. If that is the case then this question has nothing to do with configuring a real WLC and is really a question about how to use Cisco training software which should be posted in an appropriate training forum or whatever support is provided by Cisco Networking Academy. There's a Facebook page at https://www.facebook.com/cisconetworkingacademy/ and see https://www.netacad.com/courses/packet-tracer/introduction-packet-tracer
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
