TKIP
splantier
Community Member
Will TKIP work with AP350's, AP1100's and Dell true mobile cards. Or what is the best security solution for intermixing Cisco AP's with Dell True mobile cards in addition to WEP?
Thanks.
Not applicable
TKIP will surely work with AP1200 and 1100 , Not sure about Dell cards.
See this:
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1100/accsspts/i12211ja/i12211sc/s11auth.htm
michael.kopp
Level 2
Level 2
I think for almost any Dell Truemobile Card there is a WPA compatible driver. Then if you upgrade your APs to the newer images for WPA support, you should be fine. Both TKIP and MIC (called Michael within WPA) are a part of WPA solution.
Have also a look at http://www.wi-fi.org/OpenSection/protected_access.asp
regards
Michael
