To provide a wireless LAN connection method between multiple APs. (bridge mode)
Translator
Administrator
Administrator
Hello.
We assume a local environment in one segment. Connect a wired LAN terminal to the LAN I/F of each CBW150AX.
Is it a discouraging/technically difficult point to use?
Translator
Administrator
Administrator
If you look at the information below, the mesh extender is CBW151AXM (end M), and the wired seems to be not installed.
Understanding CBW150AX and CBW151AXM - Cisco
https://www.cisco.com/c/ja_jp/support/docs/smb/wireless/CBW-AX/kmgmt3378-get-to-know-150ax-151axm.html
Therefore, if you want to "hang the PC on the wired port" like the image below, I think that it will not be possible to realize it.
(Since I don't have a real machine, it is assumed from documents etc.) )
Rich R
Yes it is best to have every AP connected to the LAN directly.
Mesh (AP-AP radio connection) will always perform worse than LAN connected.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Translator
Administrator
Administrator
Scott Fella
That model doesn't support ethernet bridging.  You need to find an indoor access point that supports ethernet bridging, which allows connection to video cameras, PC, or even a switch.  Here is a link that might help provide you some context of what you are looking for. Ethernet Bridging enables connection of remote wired networks using the ethernet ports of MAPs.
https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-9124ax-access-points/221557-configure-point-to-point-mesh-link-with.html#toc-hId-1692179264
-Scott
