Total number of configured WLAN:s in WiSM, is it really 16???
jilahbg
Hello
I have a customer which network is based on 2 6500:s in the serverroom. The WAN is a L2-network with 802.1q-trunks and all Vlan:s are routed in the 6500:s.
Now we want to implement Wireless and 2 WiSM:s have been purshased. But now we find in the spec:s that the total number of Wlan:s are 16. And even as low as 8 depending of AP models.
Can this really be true?
What we want to do is to provide a department of wireless-access to the same vlan as their wired network. The network consists of a large number of vlan:s (as high as 4-500) and we want to provide wireless access on a lot of these places.
This means that on each physical location we do only want 1-2 Wlan/SSID:s. However, the total number of SSID:s/Wireless VLAN:s in the WiSM should be plenty much more than 16.
Is this possible, or are we thinking wrong?
Best rgards
Jimmy
Scott Fella
Depending on the AP, you can only have 8 or 16 SSID's. YOu shouldn't have the wireless users on the same subnet as your wired.... not best practice. What you should look at is AP-Groups... this allows you to have a single SSID mapped to various (wireless) subnets. This should help you:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
-Scott
